Cura isn't talking to the internet to slice, but it is strying to create a local socket. So it could be that nordVPN is somehow interfering with that.
- 4 weeks later...
When I installed Cura 4.8 it sliced one time then stopped. I could not get it to slice so I uninstalled it then installed it, it sliced. After I set things up to my regular settings it stopped again. At this point I figured it may be my settings. I have had problems with retract stopping mid print so I normally just enter as many 9's as it will take and move on. I went back to my retract settings and backed out one 9 and it sliced. I put the extra 9 back in and it stopped.
At this time Cura is working fine on Windows 10 pro with this retract setting.
One my Imac I can max out the retract # with no issues.
Try unticking Enable Bridge Settings option. I have the same symptoms with that enabled.
Edited by rafiqp- 4 weeks later...
Same issue started today after updating from 4.8 to just released 4.9.
Will not start slicing
Just to join the queue, 64bit windows 7 pc Cura 4.8 works fine. Installed 4.9 today program starts nice but doesn't start slicing any STL with any of the profile settings.
Please help!
Thank you!
I apologize but couldn't edit my post above.
After reading some more it seems this problem is not caused by Cura.
I switched off my over zealous firewall and it solved the problem.
The firewall would prevent certain parts of Cura to communicate with each other....
I can slice everything with 4.9 now...
Please try tuning off/disabling your firewalls temporarily to check. Then create rules in your firewall settings.
I want to thank the Cura developers for their work! Please keep it up!
GregValiant 1,231
There are a lot of comments about slicing problems with 4.9 on GitHub. I'm sure the Cura team is working on the situation.
In the meantime, load a model and use "File | Save Project" and post the resultant 3mf file here.
Then go to "C:\Users\...\AppData\Roaming\cura\4.9" you will see the Cura.log file. Post the log file here as well. The Cura team will need something to work with to find and fix the problem and more information is better.
I know it won't make you feel any better but I'm not having any problems on my Win10 machine so not everything is broken. Hopefully whatever is wrong will be easy for the team to find.
Edit: Perfect. Hopefully all will be resolved as well.
Edited by GregValiant
KaraokeAmerica 3
You show no network connection in your systray. Check that and make sure you have allowed Cura through the Windows firewall and turn off the VPN if you are running it to see if that helps.
