He can answer the simple question if it violates the warranty.
But you should contact your reseller immediately. I strongly suspect every reseller has seen every possible problem including this one. I don't have the Material Station - just the plain S5. But I've heard many people ask questions in this vein and the answer is very often: talk to your reseller.
Dim3nsioneer 528
10 minutes ago, gr5 said:But you should contact your reseller immediately. I strongly suspect every reseller has seen every possible problem including this one. I don't have the Material Station - just the plain S5. But I've heard many people ask questions in this vein and the answer is very often: talk to your reseller.
That is a very good advice. The reseller is always first choice to ask warranty questions. I cannot speak for other resellers or Ultimaker in terms of warranty. I can only refer to the warranty document by Ultimaker: https://support.ultimaker.com/hc/en-us/articles/360011627400-Ultimaker-S-line-warranty
gr5 1,517
I don't know but I suspect you won't violate your warranty by opening the MS. Contact your reseller to find out what to do next. @Dim3nsioneer is a reseller in Switzerland and he's very smart. He should be able to tell you what to do next although there is a chance that you need to contact your reseller anyway.
