Posted
(edited)
· AquaSys 120 not sticking to Ultimaker PC
On 1/14/2021 at 10:35 AM, jficara said:
I am running into an issue with the AquaSys 120 and Ultimaker PC filament, with the support autogenerated by Cura. The AquaSys 120 support filament is not adhering to the Ultimaker PC
I am running into the exact same problem - the AquaSys won't stick to the PC no matter what I try. I have a slightly different configuration with AA0.6 (3D Solex) & BB0.8, but all the same results. PC (black) is printing great, AquaSys is adhering well to the build-plate and to itself, and the extruded AquaSys looks good (no bubbles, etc). Material is fresh from the bag right into the material station. But the AquaSys will not stick to the PC part and it also seems not to want to stick to the PC of the prime tower either.
The reverse situation is no problem - PC sticks to the AquaSys just fine at the top of the supports and my supported surfaces look good. I just cannot get the support bottom interface layer to stick to existing PC, as happens when support starts on the part. I'm running the AquaSys at 245C, the max listed temp and I've tried reducing the support floor speeds down as low as 8mm/s. I've tried increasing support floor density and tried different support floor patterns (concentric, lines, etc). I just cannot get even the smallest dot of the AquaSys to stick to the top of the PC.
This is super frustrating, as outside of this issue, the material works really well. I'm running out of things to try, save for pushing the AquaSys temp up outside of its listed range. My PC is printing well at 275C, so I wonder if printing the AquaSys at something closer to the PC temp might work better. I'm hesitant to go beyond the 245C listed max temp, but other than that, I can't think of anything else to try. Maybe increase the flow rate on the support floor to try to squish it down more? Try to get the chamber temp up somehow (it's running around 40-42C right now)? Anyone have any ideas? It is a material station certified material, so I kind of expected better results - maybe someone from Ultimaker could offer some thoughts?
Edited by rachael7 Additional Information
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
rachael7 70
Edited by rachael7Additional Information
