Try re-formatting the SD card and blow out the card slot in the printer. Have you ever used Cura to send a print over the USB? If you have, and you know the computer and printer can communicate, then you can hook it up to the computer, start Cura, load a gcode file (or slice something) and go to the Monitor screen. Try sending G28 from Cura and see if it the printer homes.
If that stuff doesn't work you can try sending M502. That will do a full reset back to factory defaults. You will lose your Home Offsets and Steps/mm calibration stuff. You should be able to get those from the printer before you reset it and then you can just re-enter them afterwards. When this happens though it's often the SD card.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
GregValiant 1,141
jeff5 1
Changing the SD card and blowing out the printer worked. Thank you
