Posted · Help --> Show Configuration Folder doesn't work
Hello,
to set up my Snapmaker 2.0 correctly I'd like to install a plugin for previewing. In order to do that I'd need to choose the menu Help --> Show Configuration Folder. Unfortunately that doesn't open any folder. I've also searched for the cura folder on my Windows 10 machine but can't find it. I've set hidden files and folders to visible, so that shouldn't be the problem.
I'm very new to Cura and 3D printing in general so please forgive me if this is a dumb question. Any help is greatly appreciated.
    Installing a plugin doesn't need the plugin folder to be opened. You can just drag your .curaprofile onto cura and it will be installed.
    On windows the folder is located at C:\Users\\<your username>\AppData\Roaming\cura\<Cura version>\
