thanks for the info. where can i find the "move material" option?
Had a friend look at the printer, he fiddled with the temrature settings of the nozzle, increasing it from the default to around 240 for regular PLA and that did the trick. I'm curious as to why isnt the default temp. good enough? why should i change it?
gr5 1,557
You want feeder tension screw at the midpoint. If you fight the printer you should be able to pull with at least 10 pounds of force on the filament and it shouldn't slip. This is a good test of many things at once (did you close the feeder with the lever - did someone assemble the feeder wrong - is the feeder defective, etc).
Have you done "move material" option on the S3? Try that. You should be able to get a stream of filmanet coming nicely out of the nozzle. If you put a kink in the material you should be able to get the kink to reach the build plate within about 10 seconds.
If that's working then please show a picture or video of what you mean by "very thin strips". It could be a leveling issue or something completely different.
