Support Questions
gustrowsky
Posted · Support Questions
There are many options for adjusting the amount of support.
By default supports normally extend past the print by 3mm or so which you can adjust with the support horizontal expansion setting.
There is a Support blocker to stop unwanted support
Also the support angle can be adjusted. I find I can normally print fine up to 60deg and default is set to 45deg.
This page Here will give you a lot of useful information to improve your supports.
        • 6 replies
