GregValiant 1,142
The problem may also be in the transition between the single line width for the sharp end, and the point where it becomes 2 line widths.
I wonder if slicing with the Arachne version would be a better choice? It is variable line width and might result in the print being closer to the model as it moves up the chamfer.
How sharp do you really need the end to be? You may be able to live with it just not printing the problem layers. I printed some cookie cutters for Christmas and used .8 wall and a .4 nozzle all the way up the side walls. They worked fine.
DivingDuck 97
You maybe can play a bit with print speed / temperature / fan speeds for your last layers. With such walls at the end of a print the usual settings may not work well and the adhesion will come weak because of not consistent filament temperature.
