Posted · Filename not updated after Save Project (Cura 4.8.0)
Hi, usually I launch Cura. Then, File->Open File to open a 3mf file with the settings I use, make some modifications on the settings and/or STL and then save under a different filename. However, the top left of the Cura window still shows the original rather than the new name. Is this a bug?
For example, I launch Cura. Open a file called filename1 and make some modifications. Then, I go to File->Save Project to save it as filename2. However, the top left of the Cura window still shows that it is under filename1 rather than filename2.
