S5 "Finishes" print after failed nozzle probing
Hops
Posted · S5 "Finishes" print after failed nozzle probing
What it says on the tin. When the S5 has a failed nozzle probe , which is 1/4 prints or so for me, it will perform one of two behaviours and ive no idea what they depend on.
  1. nozzle probe fails and after the cooldown cycle tries to probe again, almost always the 2nd time works with no interference from me
  2. nozzle probe fails and after the cooldown cycle pretends that it finished the print (you can see in cura that it thinks it finishes a multi hour print in a minute.
Im of the opinion that after a failed probe the UM5 should ask if you wish to try again. Either way i dont think this should count the print as finished and remove it from the que.
        • 9 replies
