Posted · Post Processing Script not working in Cura 4.8 anymore?
Hi all,
I just tried to add a material change at a certain Z height to my g-code by using the post processing script "Filament Change" from the Extensions->Post processing menu in Cura 4.8. Unfortunately this did not work. My UM2 did not initiate the filament change and an inspection of the generated g-code showed that nothing was inserted at the layer where I had specified the change.
Is this a bug or did I do something wrong?
Best regards,
Reiner
    First of all: don't use "Filament Change" for Ultimaker 2 (or newer) printers. It uses gcode M600 which is simply ignored by the printer.
    Use "Pause at height" instead (and mind the comments for "Extrude Amount"). During the actual pause use the material change function from the printer menu.
    That's a different topic - dunno 🤷‍♂️
    Good information, thanks! Now that I know what to search for, I actually found the M600 in the g-code - just not where I expected it... I configured the Filament Change for Layer 803 and then searched for ";LAYER:803" in the file where I expected the change command. It is actually inserted before ";LAYER:802", two layers earlier than I expected it. I guess the plugin and Cura have a off-by-one issue where one starts counting from 0 and the other starts at 1.
    Regarding the "Extrude Amount" setting: The help for that parameter talks about 128mm for an UM2. That sounds a lot since the change procedure of the printer already ensures that the filament is transported to the nozzle. Do you use such a high value?
    Yep. Layer numbers in (Cura generated) gcode files always start with index zero. So ";LAYER:0" actually marks the first layer and so on. And (i think) most of the post processing scripts insert their stuff before the layer starts. So it should better be named "Pause before layer" or such... 🙂
    Me personally? Nope. 🙂
    The change procedure retracts the material to the "end-of-print" position after completion. That's 20mm by default. In addition: with gcode-flavor "Ultimaker 2" all extruded values are interpreted as volumetric amount. For filament diameter 2.85mm and 20mm length the volume is approx. 127.6mm³
    That's where this number comes from.
    So... it depends. For default firmware and default gcode-flavor: 128 is about right. For all other cases... use whatever the end-of-print retraction is set to.
    Good luck!
