My first thought was: "dirty glass". If you clean it with soap or window cleaner, be sure to clean it again afterwards with pure warm tap water only. Best twice. Thus no more soap. The reason is that soap reduces bonding too. So you really need to remove all traces of soap and detergents. Don't ask how I know this. :-)
After a closer look at your photos, it looks like the bottom "sausages" are quite round, not very much squeezed into the glass. That could also reduce bonding. So, in addition to cleaning, I would also check bed leveling, and bring that closer if necessary.
Also check if you don't have underextrusion, thus too thin sausages, which could cause the same effect: the print not squeezed into the glass very well, but now due to lack of material, instead of the glass being too far away. If you have twice the contact area per extruded sausage, then you have twice the bonding strength.
The bottom of my prints usually looks like this:
Torgeir 289
Hi @philippe44,
Well, I'm used to adjust the bed often, but sometime less often.
The bed is cleaned by using a scrape, a small one normally used to remove paint from windows..
If I'll forgot to do this for too long, my print will start to lift off the bed, because it start crimping at the top and will soon snap off the bed because of poor adhesion.
So first thing, make sure you've marked the up side of the bed (I'm using a permanent marker) , clean the bed with a scrape, then wash with "hand warm" soapy water, if you've printed some "nasty" filament you might need to use alcohol/isopropanol as well. After the "bath" of the bed, rinse well with tempered water and dry it. Avoid finger print on the print side..
Next is to do a bed adjustment, remember the (Z) height micro switch and the mechanical parts do wear a little over time and also -might need some lubrication.
I'm using a note from an ATM as a space (height) detector. When starting this adjustment, firmware ask you to adjust to approx 1 mm the inner mid position by using the wheel knob. Then to do the same on first outer R/H corner and lastly L/H corner -for both adjustment here using the turn knob under the bed..
Round two is to be done withe the "note from the ATM", the inner mid point with the wheel knob -here just one notch will release the ATM note -if so you made a very good adjustment! Next in same order as above, using the note and the turn knob under the bed. During this adjustment it is easy to push or pull the knob so the adjustment will be in error, so remove your finger from the knob in between adjustment to make sure your adjustment is good.
Sometimes I've seen that the 110% first layer feed is to much, so I'll adjust it to 100% to make a clean and even first layer.
This might not be an issue for anyone, but might be something for some..
Good luck
Thanks
Torgeir
