Hi- Yes, I previously had problems with the print bed and just ended up replacing the whole print bed.
I was actually wondering if it isn't the print bed again, that is the issue. I believe that the nozzle won't start heating up until the print bed is at 170, is that right? So if the print bed doesn't heat up, or somehow gets skipped over in the beginning operations of a print, then the nozzle won't either. Maybe....
No I have no tried to control the printer using Pronterface. I have no experience with Pronterface.
Torgeir 161
This is strange, I've seen into your previous posting that you had a problem with heating the heat bed..
How did you solve this problem then?
I'll don't think it is a firmware issue, unless you tried to alter printer setting using gcode..
Have you tried to control the printer using "Pronterface" via USB?
Thanks
Torgeir
