GregValiant 1,488
1000/25.4 = 39.37
So sometimes it's probably meters, and sometimes it's something other.
At any rate as ahoeben says it's likely in Solid Edge either in the drawing units, or it's an STL export utility setting.
1000/25.4 = 39.37
Wow, you were right guys.
I loocked it up and even tho i drew my designs in mm's STL export was in inches, don't know how i missed that.
THX A LOT!!!
ahoeben 2,047
This sounds like somewhere in your workflow there is an inches to mm transition. The STL format does not specify a unit, so Cura (along with many other applications) assumes the coordinates in the STL file are in mm. It seems SOLID EDGE may have exported them in inches instead. See if there is a preference in SOLID EDGE to export in mm instead of in inches.
