I'm guessing your box is "close" to the size of your printer's abilities. You can lookup what Cura thinks your print volume is by:
Go to left side of screen in PREPARE mode. Click on your printer, then do "manage printers" then "machine settings"
If your object dimensions are smaller than those dimensions then there are still a few things to do. Some settings to change such that cura doesn't print outside your box.
set "travel avoid distance" to zero.
disable brim and skirt both!
details here:
https://support.ultimaker.com/hc/en-us/articles/360013799339-How-to-print-the-maximum-build-volume-in-Ultimaker-Cura
gr5 1,557
Are you going to print it on your S5 or on your Ender 3?
