Printcore in head slot X is taking too long to warm up - Ultimainboard reboot happening in the background
Posted
· Printcore in head slot X is taking too long to warm up - Ultimainboard reboot happening in the background
Did you manage to solve this issue?
Our Atmel board also started rebooting during a print.
I also put the printer into dev mode to get logs, and as you see below it seems like the same issue. However, I never got the error "Printcore in head slot X is taking too long to warm up", as you did.
The error occurred in a PETG print, with relatively high temps. I was thinking it might be the powersupply having issues, so I will test with lower bed temp and lower print core temp, to see if I still get the error.
Snippet from logs:
Feb 16 08:25:42 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:25:42,221 INFO timeEstimator getTimeRemaining() total_time 20:20:12 scaling_factor 0.9526796062937224 compensated_total_time 19:22:27.579336 time remaining 18:02:26.854937 pure_cura_time_remaining 19:00:11.275388
Feb 16 08:26:44 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:26:44,481 INFO transportLayer BUILD:Jan 27 2019 22:52:07
Feb 16 08:26:44 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:26:44,486 INFO transportLayer Detected board with id #2
Feb 16 08:26:44 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:26:44,492 INFO transportLayer ADS1015 #0x48 ref.voltage=958
Feb 16 08:26:44 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:26:44,495 INFO transportLayer Marlin started
Feb 16 08:27:04 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:27:04,508 WARNING transportLayer ProtoError:Sequence number is unexpected (received, expected): 189,0
Feb 16 08:27:04 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:27:04,510 WARNING transportLayer Protocol error from Marlin received, send buffer: [MessageTuple(sequence_number=189, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12d68>, in_planner_buffer=False), MessageTuple(sequence_number=190, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12e88>, in_planner_buffer=False), MessageTuple(sequence_number=191, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12db0>, in_planner_buffer=False), MessageTuple(sequence_number=192, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12e40>, in_planner_buffer=False), MessageTuple(sequence_number=193, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12930>, in_planner_buffer=False)]
Feb 16 08:27:04 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:27:04,617 WARNING transportLayer Resend data request for sequence 0, but not found, before adjusting: [MessageTuple(sequence_number=189, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12d68>, in_planner_buffer=False), MessageTuple(sequence_number=190, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12e88>, in_planner_buffer=False), MessageTuple(sequence_number=191, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12db0>, in_planner_buffer=False), MessageTuple(sequence_number=192, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12e40>, in_planner_buffer=False), MessageTuple(sequence_number=193, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12930>, in_planner_buffer=False)]
Feb 16 08:27:04 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:27:04,619 WARNING transportLayer Resend data request for sequence 0, but not found, after adjusting: [MessageTuple(sequence_number=0, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12d68>, in_planner_buffer=False), MessageTuple(sequence_number=1, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12e88>, in_planner_buffer=False), MessageTuple(sequence_number=2, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12db0>, in_planner_buffer=False), MessageTuple(sequence_number=3, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12e40>, in_planner_buffer=False), MessageTuple(sequence_number=4, message='M105', callback_function=<function ApplicationLayer.__getIdleCommand.<locals>.<lambda> at 0x9ed12930>, in_planner_buffer=False)]
Feb 16 08:27:04 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:27:04,737 INFO transportLayer too long extrusion prevented
Feb 16 08:27:46 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:27:46,092 INFO transportLayer cold extrusion prevented
Feb 16 08:27:46 ultimakersystem-ccbdd30032e5 python3[874]: 2021-02-16 08:27:46,257 INFO transportLayer cold extrusion prevented
ndu 0
Snippet from logs:
