I mean, that's nice and all... but it's not in the gcode file and it's a manual process that I need to remember to do on purpose.
GregValiant 203
I think this is what you want HERE.
You copy and paste a bunch of lines from the log file (that you download), and paste it into your Machine Settings End-Gcode. It's an older file and you might have to cross-reference the keywords to make sure they are all included and that none have been deprecated (they are HERE). The plan is that when you generate a gcode file all the keywords get replaced by the actual values from the settings in Cura. I haven't used it (too much information) but it looks like it would be laid out nice and neat without all the newline characters that are in the partial current Cura settings at the end of a file.
1
1
- 2 weeks later...
Thank you, that's exactly what I needed
On 2/8/2021 at 5:41 AM, GregValiant said:I think this is what you want HERE.
How i can insert the Material Extruder1 or Material Extruder 2 like the Filament Name, it seem like it is not icluded inside this settings
2 hours ago, Quteibaaaaaaaaaaa said:How i can insert the Material Extruder1 or Material Extruder 2 like the Filament Name, it seem like it is not icluded inside this settings
Did you check the second link in the post, the one that shows all "settings and replacement patterns"? If it is there you should it add to your end-gcode. If you cant find that second link, here it is...
http://files.fieldofview.com/cura/Replacement_Patterns.html
Edited by Mari
I did but i did not actually find it this is how i mean that, this settings is from the Marktplace Cura settings to HTML
but i want to have them inside my G-code. and after that i print the Settings insidide Excel
the reason that i do not use Cura settings to HTML is, that i have to download the HTML table every time when i Upload the G-code
https://drive.google.com/file/d/1hblB0gdgCTSX0tbUsvPCEmzYjWTFKZWm/view?usp=sharing
If you share something on Google-drive, make sure it is public... Now I need to ask permission...
Maybe there is a "replacement pattern" for the info you want but it is not in the list... Contact the developer of the HTML-plugin, maybe he can tell you what "replacement pattern" to put in you end-Gcode to get the info in the Gcode-file...
1
- 2 weeks later...
On 2/20/2021 at 12:06 PM, Mari said:If you share something on Google-drive, make sure it is public... Now I need to ask permission...
sorry, for that, i just share the HTML Table of the Settings, nothing important, ok i will get in Contact with him, thanks very Much !
Mari 28
There is a plugin that can export you Cura settings to HTML...
