Brillian. Thanks for the tips I'll take a look.
GregValiant 1,141
The end cabinets (that I suppose the drawers go into) might be able to be rotated open end up so they don't need support on the inside.
When printing things with large flats on the build plate you can often get by with a skirt instead of using brims. They use less material and don't need to be trimmed off while still getting the flow going. So I would do the legs as a separate print with a brim (so they don't fall over), and the rest of the stuff with just a skirt.
Edited by GregValiant-
1
gr5 2,094
This is extremely common. It's a problem with your printer. First you need to know if it slipped in X or Y. Then concentrate only on that axis. I'm guessing you have one of those printers where the bed moves in Y - it's most likely that axis if you do.
So then something slipped. Some pulley on the stepper or pulley on a belt. Those pulleys have a tiny set screw. Tighten the hell out of that screw. I mean so tight that if you use an allen wrench and hold the short end of the L in your fingers it hurts. A lot. the shaft should twist slightly. That tight. Then try printing again.
GregValiant 1,141
In addition to gr5's suggestions you want the belts to "twang like the strings on a bass guitar". If they're loose they can jump on those pulleys you just tightened and cause that layer shift.
