Weird behavior about wall
Fabiuz
Posted · Weird behavior about wall
I was creating small models to test if my printer is able to replicate very small details.
I had tried to print a very simple grid, but I get an expected behavior. The bars are equally spaced, so empty spaces and bars have the same width. I don't get why the model on the right (0.5mm) doesn't get properly sliced. My line width is set to 0.4, so I don't think that "thin wall" matter. "Compensate inner/outer" wall doesn't change the behavior. I attach the 3mf so all the parameters are available.
I have attached the models.
test righe 0.5.stl test righe 0.6.stl CE3_test righe 0.6.3mf
    Cura does not generate "single line walls" - it never has. If you look closely on the bars on the left, you'll see two wall lines. Cura automatically reduces the linewidth, but only to a certain degree (max. 3/4 of the configured linewidth). That's why 0.6mm works even with a 0.4mm nozzle (two 0.3mm lines), but 0.5mm not anymore.
    Ok thanks for the answer! I can imagine such behavior but I didn't found any documentation about "automatic" line shrinking.
    However I don't understand why Cura prints the external vertical bars of the model on the right side. All those vertical bars are 0.5mm.
    Not entirely true; The Arachne build does.
    13 minutes ago, Fabiuz said:
    Is Arachne engine part of Cura v4.8?
    No, there is a special build that contains an experimental version of CuraEngine. It is not quite Cura 4.8, but closely related to it.
    See this thread:
    Ok thank you, I will take a look!
        • 4 replies
