6 minutes ago, GregValiant said:You can ty it with tree supports to see how it looks. Without support that roof won't print correctly.
Tree support seems to lead to odd result. Thank you!
Edited by curasurf6 minutes ago, GregValiant said:You can ty it with tree supports to see how it looks. Without support that roof won't print correctly.
Edited by curasurfThat is a very odd result. The tree should grow from the build plate and not the part.
I wonder if there is a problem with the model and Cura thinks the tree supports should be from that side when in fact they are growing through a wall?
If it isn't a proprietary part - post the STL.
@GregValiant I attached STL in the last post, but ... lost...
The model is good. I suppose you have a reason for not printing them lying down.
@gr5 - take a look here. I get the same results as Curasurf and am unable to get the tree supports to support the slot roofs on the other side of the model.
GregValiant 206
