1 minute ago, Smithy said:I would contact your reseller, maybe you need just a new front fan if something is damaged there.
I have contacted the reseller and they are sending me a fan, I have dismantled the axial fan assembly and can't see any issues other than the fan blade part has lots of play in it and suspect that when it runs the blades move towards the casing and cause the problem.
I'll post again when the new fan is fitted, hopefully it will cure the problem.
Smithy 793
