Please include photos. With arrows to what you don't like. Maybe the quality you are getting is already better than most people could expect or maybe your quality is truly bad. I have no idea.
As far as printing settings, any Nylon profile should work fine. Personally I print 0.2mm layers. My prints are functional and I don't care if layer lines are visible. In my opinion the quality is great but I'm sure other people would say it looks like garbage.
I care about dimensional accuracy more than how it looks so my settings may be completely incompatible with yours (there are tradeoffs among accuracy, prettiness, speed).
Nylon has to be kept amazingly dry. If it's very wet it will pop and sizzle and you can see steam coming out of the nozzle. But even if it doesn't sizzle it might be just humid enough to lower quality. non-fill nylon will be glossy smooth and if there is no dye it will also be transparent on the bottom layer. wet nylon comes out more snowy.
Two days sitting on the back of my printer is enough to "ruin" a spool of nylon although it's easy enough to dry it (gee where can I find a thermally controlled bed to leave the nylon sitting on for overnight? Put it in a box or under a few towels and be very careful not to go too hot - but most nylons can handle 100C fine so I dry nylon at 80C)
dcschooley 9
What is it about the finish on NylonX that you don't like? NylonX has a textured finish and the layer lines basically disappear. I love the finish on NylonX parts. Make sure your material is really, really dry.
