1 hour ago, fvrmr said:You could try to change the minimum support area. So add the mm2 of your holes there and no support will be printed.
Thanks - yes, that worked although I had to do it via trial and error.
1 hour ago, fvrmr said:This depends on the placement of your model. If you look closely you will probably see a zigzag line but different than the other infill.
Certainly changing orientation changes the degree of zig-zag. It seems that the orientation of the zig-zag doesn't relate to the model, but to the base grid.
As always, thanks again
1
fvrmr 73
Hi @emtee
Please let me know if you have more questions. Or if the minimum support area doesn't work.
