I got this working, I am actually not sure what did it but now the start and end gcode appear to be what I want them to be. I uninstalled again and then started messing with the .json definition files. Adding some dummy lines to see if they show up both in the config and in the posted gcode. I am not exactly sure what did it but now the correct start and end codes are loading.
I guess I could call this closed but I have no clue what I actually did to fix it. Not gonna look a gift horse in the mouth tho..
GregValiant 1,141
What exactly is happening that's troublesome? Is the printer processor locking up? Wrong temps? Although the order of the commands is different they appear to be workable. Cura explicitly calls out T0 at the start and the other file does not. The other file has M107 P1 (turning off the layer cooling fan of the second extruder) and the Cura file turns off the fan of the active extruder which appears to be T0.
