Regarding #1 - leveling is sensitive to electromagnetic radiation so keep laptops, cell phones, other electronics at least 10 cm away from the printer to see if that helps.
Sometimes you have to replace the larger PCB inside the head (I think - not certain). Your reseller can help you out there. They can sell you any part even though they don't usually show all the parts on their website.
gr5 1,557
Ultimaker 3 can do manual leveling which I find to be just as good and much faster than active leveling (since you only have to manual level once per month or so). So that can solve issue 1 and 3 potentially. Buying a new BB can solve issue 2 but BB cores aren't too hard to clean.
In the maintenance menu on the printer you can do hot and cold pulls for that BB core. I recommend that.
What happens is that PVA when at printing temps slowly (over many minutes or even hours if you haven't used that core for weeks) caramelizes into brown and black gunk that has trouble going through the nozzle.
