Hey!
I actually figured it out. Our power had gone out and the wifi connection got screwed up. We always just use wifi to send over prints. My colleague was using a USB but not leaving it in the printer so that error would end up happening.
Best,
John
gr5 2,094
Can you post the log files please? Just ones with the word "boot" in the filename. Also please post the exact gcode file that generated this error - I want to check line 31391.
Did you print over network or from USB flash drive? If from USB, please copy the file off the USB stick as it may be corrupted on that line of code but only in the gcode file that is on the USB.
