1 minute ago, Smithy said:I did it for you for the previous post:
Generally it should be the original author who can mark it as solved. This seems to be a bug 😃
3 minutes ago, Smithy said:But there is a second way, the way you showed in your initial post:
Don't use the tag, use the "Item prefix" below. But I am not sure if you can do it. But you can try if you edit your first posting, then you should get that screen.
No, I can't do it.
In most forums, only the original author can mark a post as solved. Here only "special" (?) user, but not the author, can mark a post as solved. This is a weird rule.
You are right, I was not aware that the original author is not able to do it.
I will report it to the forum admin, maybe he can enable it somehow.
@curasurf It should be fixed now! You need to select the tag first, and can then set that as the prefix.
Smithy 793
