Thanks for the help. Good to know where to look.
I figured I was going too fast because the temperature is set to 190 for PLA. I'd think thats enough isn't it?
I looked at the infill speed and it was set to the same as the regular speed. I set it to 0 anyway.
Maybe I have a clog or something? Not sure. Thanks for the tip on what to look for.
gr5 1,969
This is typical underextrusion.
You areprinting the infill either too fast or too cold. I guess I'll go with too fast.
Cura allows you to do a higher speed on the infill. This is not a good feature. Set this to 0 so that it goes at the same speed as the rest of the printing. Alternatively slow down the entire print or raise the temperature to allow more filament through the nozzle.
