Hi @CarloK, thanks for the reply and info.
Unfortunately I had a flooded print head so in taking this apart, the pt100 and heater cables had to be sacrificed. Cleaning up the head and core, I see there is no connector/ferrule, just the wire straight onto the core board so one less thing to worry about.
Would a Ultimaker reseller be able to actually supply these parts? Would they come to the cut length already with the heat shrink? As you say, if the original wires on the Ultimaker spec are extra flexible, makes sense to stick with those.
Many thanks,
CarloK 208
Not sure why you want to order a PT100, those are passive components and almost indestructible. These are PT100-B types and when you ensure the dimensions are the same you can order them everywhere for less than the original Ultimaker replacement parts. Then you will have to cut the wires to the desired length yourself.
Same goes for the heater element.
Most likely this is the exact same component as used in the UM2. Note that the UM2+ uses a 35W heater, this won't work.
All printcores use the same 25W heater element (AA, BB, CC cores and all diameters).
A last note on the heater and PT100 from Ultimaker is that the wires on these components are extra flexible. This because of the movements in the Printcore. Cheaper replacement components will be less flexible and wires can break.
