23 hours ago, wckdawe said:Is the "alpha" version of cura available for anyone to use currently?
Oh! yes. Go to the normal download page for cura:
https://ultimaker.com/software/ultimaker-cura
Then just below the huge download button click on the "previous" versions link. There's only one version with "alpha" in the title.
gr5 1,606
Ha! This is basically the only question as I see it.
1) Well you can switch to 6 lines and make them all thinner. That may work better than you would suspect. With a 0.4mm nozzle you can typically set "line width" down to 0.3mm (75%) without too much loss of quality. So I'd try that. Usually 75% to 150% range works okay.
Thin walls are tricky
2) The new version of Cura - the "alpha" version supposedly does things much different and I think *maybe* it can do 5 lines instead of 6 for walls? I read what it does differently... and then forgot most of it but I seem to remember it can do walls with odd numbers of lines? Maybe? Or maybe it will be able to when complete? It's still many months away from completed I think but it's worth a host.
3) The "MB" version of cura just does a much nicer job with thin walls. I don't understand why - it just does in certain cases. Your walls might not be thin enough that there is any difference. I'm not sure what MB does differently but you could give it a shot. It's quite safe to use and try out. "MB" are initials of a user on this forum "burtoogle" aka "smartavionics":
https://github.com/smartavionics/Cura/releases
wckdawe 1
@gr5 The minion has replied! ❤️
Okay, I'll give it a try with a smaller line width. I think i can do the base of the lid with 0.4mm line width, while the "wall" side (above the 0.24mm) with 0.3mm. I'll give that a few tries when I get the chance later today.
I'll have to take a look of @burtoogle 's build to see what's so awesomely different about that.
OH WAIT. that guys is the custom cura sunshine builder! Hey! One post and i get to meet both of you. 🥳
I'll keep you updated as soon as I give anything a try. Thanks again! 🙂
