7 hours ago, CarloK said:Since you use it often, what do you think of the default settings for the Adaptive Layers?
In my understanding,
1. Layer Height ± Maximum Variation
The range of layer height need to be defiine according to the overhang condition of a model
2. Variation Step Size
This is only for the transition of different layer heights. It can simply be set at the default value.
3. Topography Size
This is the key setting. It means the distance at which every two neighboring layers are shifted from each other in the X/Y plane. It determines the quality of all the overhang walls. The smaller Topography Size, the better quality, the smaller layer height, the longer printing time.
Edited by curasurf
CarloK 202
I like the feature too, but with mixed emotions. It can reduce printing time a lot, but I always have to compare to the default settings since it can increase the printing time too.
For others to learn, how do you use this feature? Are you tweaking settings? If yes, how do you do this?
