GregValiant 1,142
Just to make it more complicated - Sketchup is notorious for producing STL files that are poorly constructed and in need of repair. You can upload your STL to service.netfabb.com for repair. It's free but you need to make an account. I only had 1 model that was so bad it couldn't be repaired.
Have you downloaded and installed Cura? Because that is the next step to process the STL file into a Gcode file that the printer can understand.
Labern 774
Hey there.
You need to load your stl file into ultimaker Cura. Cura will then slice the model ready for you to print.
Then you save the sliced model onto the sd card and it will print for you.
