Is there a way to manually load material files onto an Ultimaker S5 Pro Bundle
Posted
· Is there a way to manually load material files onto an Ultimaker S5 Pro Bundle
What version of firmware do you have (you can check in the menu system)?
And are you using latest Cura? (4.8)?
I believe the latest firmware (and latest cura) will transfer profiles in the UFP files on the USB flash drive? Maybe? My memory isn't fantastic but I think that's a very recent firmware (and cura) feature.
Anyway if you answer those 2 questions someone else can tell you for sure.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
