GregValiant 255
How about the notorious "MAKE OVERHANG PRINTABLE".
1
thanks for the replies.
I already had "remove all holes" and "union overlapping volumes" unchecked.
"Make overhang printable" was also unchecked.
Cura crashed yesterday and I could not make it run afterwards (only white screen after each restart).
I completely reinstalled today and now the void is not filled anymore. I get the desired result.
So the re-install seems to have solved the issue.
Thanks again!
Excellent. It was some errant setting. I suppose "horizontal expansion" can also cause that issue.
gr5 1,606
It works fine for me (see pic below). make sure support is disabled. Under "mesh fixes" make sure everything is unchecked. In particular "remove all holes" and "union overlapping volumes".
If you still can't figure it out then send us your project file. That's much more helpful. Do "file" "save project...".
