Thank you for your response.
However, as I wrote in my post, the thickness of the layers seems to be very even, meaning they all appear to be exactly 100 or 200 microns thick (whether is 100, 150 or 200 doesn't seem to be making a difference). Rather the layers seem to be misaligned a bit in the X-Y direction (not Z).
gr5 2,071
This is a common problem and it is caused by Z innacuracies. So for example if you are doing 100 micron layers it might only move 70microns and get stuck. Then the extruder extrudes enough PLA for 100 microns in to a gap only 70 microns high and you get a bit squeezing out the side (over extrusion). Then on the next layer you might get 130 microns (meaning it caught back up - it moved the full amount finally) and on this layer you get underextrusion because it is extruding enough plastic for 100 microns but there is room for 130 microns worth.
If your Z screw is dirty, clean it and regrease it with the green grease. Or just add a drop of green grease (a drop about 5mm across). Also put a few drops of thin petroleum oil on each of the 2 vertical rods. Do not grease the rods and do not oil the screw. Try to keep oil and grease away from the outside of the Z nut also - you don't want any lubrication between the nut and the wood (at least I don't think you do).
What layer height are you doing? If you double the layer height you might get better results. Some people have also improved this exact thing by adding a 1kg weight to the bed (under the plastic bed). If you do that you will have to re-level of course.
