There is a one layer gap between support interface and next model layer
Posted
· There is a one layer gap between support interface and next model layer
You can set the gap to anything you want but I think it will be moved to the nearest layer. I don't think you can do support on in-between layers without changing the vertical resolution (e.g. .06 layer height).
fvrmr 73
Hi @Rivanov try changing the support roof line distance to 0.1 mm.
Let me know if that works for you!
