JohnInOttawa 104
The warning on the quick demise of brass print cores and feeders should be heeded.
I bought a used UM3 that had (i understood) about half a kilo of Nylon/CF through it. Print core and #1 feeder heavily worn. AA 0.4 was already at 0.6 and visibly shorter and flatter tipped than spec. The feeder was already worn to the point of slipping and mishandling retractions.
There is a solution though. Both of my UM3's now run Bondtech feeders (hardened and replaceable drive gears) and I use 3dSolex hardcores when printing abrasive stuff. Not a cheap upgrade but way less than an entirely new printer. I have been running this configuration for 18 months and no visible degradation.
Hope this helps!
John
tomnagel 123
You will quickly wear out your printcore, but worse is that also your feeder wheel will wear out, which will harm the performance for all materials.
For printing abrasive (filled) materials, you have to upgrade to an S3 or S5. These have hardened feeder wheels out of the box, and you’ll have to purchase a CC print core with a ruby nozzle.
