How do you disable regular supports when using tree supports?
Posted
· How do you disable regular supports when using tree supports?
6 hours ago, bmcpeak363 said:
I see that regular supports should be disabled when using tree supports
Cura does that automatically now; you can choose to either use tree supports or regular supports. In previous versions it was possible to enable both. That is no longer the case.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
ahoeben 1,886
