Unable to upload file. Make sure [it has] ... .gcode
jax200
Posted (edited) · Unable to upload file. Make sure [it has] ... .gcode
I am getting the following Octoprint error message, yet the file I am attempting to upload is indeed a .gcode file I saved after Cura slicing.   (This ended up as an Octoprint issue.)
Upload failed
Could not upload the file. Make sure that it is a readable, valid file with one of these extensions: .g, .gco, .gcode
Edited by jax200
    Posted · Unable to upload file. Make sure [it has] ... .gcode
    I don't know if it is a related issue but I also couldn't upload a file Octoprint with the plugin. Octoprint Plugin option missing after I sliced I only had the option to "save file". Figured it must have had something to do with me reflashing octopi. Couldn't find Octoprint connection option under "Manage printer" in Cura. So I uninstalled plugin and tried again twice without luck.
     using:
    Cura 4.8.0 on WIndows 10
    octopi 0.18.0
    octoprint 1.5.3
    It is not. This issue has already been marked as solved.
    Please open a new thread, and include a link to your Cura.log. It can be found in the configuration folder in Cura, which can be accessed via Help -> Show configuration folder. Please upload the cura.log file somewhere (dropbox. google drive, etc) and post a link.
