in need of a hinge STL file
FryerJon
Posted · in need of a hinge STL file
I just finised some maintinance on my 3 ext. and when I when to put the door back on I found the upper hinge had a small piece missing. So now the door falls off. I am hoping there is an upper hinge STL file someone can share.
Thanks,
Jon
    Hi Jon,
    you are referring to an "Ultimaker 3 extended" - or which printer exactly?
    The Ultimaker 3 model does not come with a door or hinges, so.... what exactly are you looking for?
