Is the project file the "STL" file?
In Cura, I went to File. The only save selections were:
"Save Profile" or "Save Model".
I did both and tried to drag them here, but files with those
extensions aren't accepted.
gr5,
Would you mind sending me the sliced file?
Thanks, Mark
I have selected machine um2go so it will only print on a UM2 printer.
What version of cura do you have?
I'm guessing you have cura 14.X or 13.X (from 2014 or 2013 respectively). The latest version is 4.8 which is what I slice your model on.
Hello gr5. I loaded the next version of the Cura software and my model sliced immediately-
so I'm all good now. I really appreciate your comments and your help. Thanks, Mark
gr5 2,071
Slices fine for me. Maybe you should post your project file - that will contain your printer settings, STL, profile, overrides, etc.
Do "file" "save project..." and post that here.
