Partially printing a model in cura
albinv06
Posted (edited) · Partially printing a model in cura
Hello,
         how can i able to print  a model partially in cura ?  Is it possible to cut the model in cura and able to print the balance of it. Below i attached the photos of my model. The figure 3.PNG is the model which i need to make changes. The fig 2.PNG is adjusted with the help of z offset. So using the z offset adjustment i can able to print top/bottom parts of the model. To check the right sizes of holes, i dont need to print the entire model. So is there is any method in cura to print the fig 1.PNG model, only the centre part of the model wihch is inside red marking?
Regards
Edited by albinv06
picture modifications
