thanks a lot for the fast answer Daid!
but is there a more detailed description somewhere? The cura-manual does not mention this possibility, as far as i know/scanned the content :???:
for example concerning the following questions:
- which file/exe would i have to address?
-how would the console-code look like? what is the output-filename for? the generated gcode?
Daid 300
Yes, you can run Cura as console program, if you give it a stl file, ini file for settings, and output filename.
