GregValiant 1,346
Yes I do. In fact I'll do @tdbinns two better.
I'm attaching a zip file containing 3 extruder files and and an altered Creality Base machine definition file. The end result will be that you could define a 4 extruder Creality printer.
The three extruder files are:
"creality_base_extruder_1.def.json"
"creality_base_extruder_2.def.json"
"creality_base_extruder_3.def.json"
copy them into "C:\Program Files\Ultimaker Cura X.X.X\resources\extruders"
The "creality_base_extruder_0.json" file will already be in the folder.
Go to "C:\Program Files\Ultimaker Cura X.X.X\resources\definitions" and make a back-up copy of your current "creality_base.def.json" file. Then copy the new base definition file into the folder.
You will be able to add additional extruders to any Creality printer. Your Ender 5 definition file doesn't need to be changed as the information comes to it with the Creality_Base Definition file.
Like being all dressed up with nowhere to go...I prepared for it and then decided I'd never need a second extruder.
- 1
gr5 2,225
@GregValiant might know.
