I looked at your stl carefully. I had to uncheck "union overlapping volumes". I don't know why you thought that should be checked. It needs to be unchecked.
Then it prints as your STL shows which may not be what you want. It prints a donut shaped void in your part where you could insert a donut shaped magnet.
I assume instead that your magnet is a solid cylinder?
If so then you have 2 problems with your model:
1) You have a double inner wall instead of a single wall to transition from "plastic" to "magnet".
2) Your normals are backwards:
In sketchup you want all walls that face air to be white and the side of every wall that faces plastic should be gray. In sketchup to reverse them, right click on a wall and select "reverse faces".
Again, "gray" should face plastic (interior) and white should face air or magnet.
I deleted the outer shell, left the grey cylinder, all white are facing inward. Still no luck. You can see in the first image that the cylinder is in the picture, but from the top view it is being ignored.
gr5 1,968
And uncheck "union overlapping volumes".
