Posted
· Problems with cura leaving out parts of my model
So that looks like sketchup. And I can see that some of the faces are white and some gray. So the first thing to fix is, in sketchup, all gray suraces - right click on them and select "reverse faces" such that the surfaces are then white.
Also make sure there aren't any interior walls that don't need to be inside your model. Those also mess up cura. Try that and if you still have trouble, post your STL file for us to look over.
Posted
Maybe I should explain better - STL files have a set of unordered triangles and each triangle has an "in" side and an "out" side. The side facing air is white and the side facing interior is gray in sketchup. If you get those backwards, Cura gets very confused and sometimes does not print certain features.
Posted
Thank you, it seems that the cylinder did extend down through the whole model and as soon as I changed that so that it stopped when it got to the top of each step it managed to fix it.
(I do apologize i should have specified what modeling software i was using but the solution that i was given worked anyways)...(I was using Rhino 6)
As seen by the dotted red line, i used the edges of the steps to trim the cylinder.
Thank you for the help, I was stuck with this for a while, I just wanted to post the process of my solution if any other people have the same problem.
1
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
gr5 2,094
JOMS 1
