I hate to beat a dead horse, but can you check the gap between the teflon and the milled fitting again?
When my prints were failing everytime, the only change I made was to the space between the teflon and milled fitting. (Posted in this thread somewhere) Since then my issues of under extrusion are gone. I don't understand why, other than the transfer of heat in the form of conduction is very accurate where the heater, nozzle and milled fitting all sit together.
Or maybe I just got lucky and failing mechanical parts are now working? Very Unlikely
Everytime I use the Orange PLA from the Ultimaker store I got a clog almost instantly. I did buy some cheap white PLA off of ebay which is printing better than all of the colors I've tried so far(go figure).
I hope you find the solution!
Ok, the gap ist 2.2mm wide. I have found a nice workflow to 0 play with the bowden tube (head). Lower the gap between the teflon piece and the milled fitting, then insert the bowden tube and secure it. Then unscrew the milled fitting so it moves up against the bowden tube a bit. This alone has eliminated any play there.
Regarding orange PLA from Ultimaker. This prints beautifully on my printer. Way better than silver-grey or gold.
Top Posters In This Topic
196
87
78
42
Popular Days
Jan 27
48
Jan 15
41
Jan 18
33
Jan 17
26
Nicolinux 196 posts
gr5 87 posts
illuminarti 78 posts
braddock 42 posts
Popular Days
Jan 27 2014
Jan 15 2014
Jan 18 2014
Jan 17 2014
illuminarti 18
Nicolinux - did you try doing a factory reset, to make sure your extruder current settings are ok, as I mentioned a page or two back?
