About the filament, I have always had this in the back of my mind.
Different colors require different temperatures, different suppliers have different stiffness.
There are so many different gradients in just 'PLA', that it is hard to tell what you get from which supplier.
Especially I think what we are suffering from now is the stiffness of the filament.
Has anybody ever checked the filament during/after under extrusion if it was still round or oval?
- How does this compare with a piece of filament that has not went through the feeder yet?
I think if you store the filament near a heat source the moist can evaporate, and it will make it more stiff or perhaps brittle? Does that make sense?
Hi Sander,
This is something I've been looking at closely with the filaments I've had, albeit only 3 suppliers. My Faberdashery filament is the most pliable of all of my filament, but still fairly stiff. The Ultimaker filament that came with my printer is stiffer than the Faberdashery, but the black I got from MakerGeeks is the stiffest of all of them (though not MUCH stiffer than the Ultimaker). This matches the ease of printing with them; the Faberdashery is the easiest, then the Ultimaker, then the Maker Geeks, but this is probably skewed by the Faberdashery having a much larger bend radius than the others.
I did a quick measurement on my filament, and a strand extruded in air is pretty round (0.39mm to 0.41mm), where the input Ultimaker filament is also round, but less so (2.85mm to 2.92mm). I didn't check my Faberdashery yet, and have stopped using the Maker Geeks for the time being.
In terms of removing moisture, I've heard this is beneficial for print quality as it will produce less defects since any water in the filament will steam when it's extruded (and make a small popping noise). I don't know how heat will affect this, since it can change the structure of the plastic of its own accord. Personally I store my filament in a bag with a large desiccant pouch I bought from Amazon, and this keeps most of the moisture out, but I've not noticed a change in stiffness.
Top Posters In This Topic
196
87
78
42
Popular Days
Jan 27
48
Jan 15
41
Jan 18
33
Jan 17
26
Nicolinux 196 posts
gr5 87 posts
illuminarti 78 posts
braddock 42 posts
Popular Days
Jan 27 2014
Jan 15 2014
Jan 18 2014
Jan 17 2014
SandervG 1,521
Hi Nico,
I have read your post and copied pasted fragments to those who should be addressed.
I will follow them up in a few days if I haven't heard back.
Thank you very much for your feedback, it is much appreciated.
@ Braddock, I understand your point about an expensive machine that is/should be reliable and how frustrating it can be when this is not the case. I also agree with Nico about the first revision part. However if that may be the case or not, in no way should this disadvantage the users.
We support all users like many on the forums now that go through all the efforts to troubleshoot the under extrusion and come with solutions. Really, that is what makes Ultimaker great!
However we are not relying on this, so Braddock if you feel you are not getting the max. out of your Ultimaker 2 please contact either me or the sales team and we will do our best to isolate your problem and get you back to your fully positive 3D Print experience. Ok?
