Almost always missing layers / underextruding
Nicolinux
Posted · Almost always missing layers / underextruding
I believe this proves the theory, in my case anyway. I printed this with retraction turned off, (a wing from my little Dragon) and it is the smoothest print I've ever had, not a hint of under extrusion.
wing 01
wing 02
wing 03
wing 04
    • Replies 754
    • Created
    • Last Reply
    Top Posters In This Topic
    Yes! Now let's try to get that bowden tube shoved down the teflon interface piece. You must get your printer up to snuff, I want to see what you end up printing with a properly functional UM2.
    Hey guys, thanks for the diagnosis.
    I took a trip to the filament trashcan and found some of those tips that were cut off when changing filament.
    filament end02
    filament end01
    I think I might have the same issue as braddock, albeit not that extreme. Regarding the bowden tube play, do you mean the whole bowden tube with the white ring at the top of the head? If yes, than I have about 1-2mm play when I pull on it. A the bottom, right above the teflon piece, I see the bowden tube moving up and down:
    By the way, the long orange filament strand was attached to the tip that I cut off. I thought, one of these days this thing will get stuck inside the extruder, right above the knurled bolt and when I push new filament in it will move inside the head and definitely cause a clog...
    I had similar, but not quite as severe, play like Nicolinux shows in the video when I first got the machine. After I got my first clog and disassembled the head I did what I describe above and now my play is maybe half a mm. My clog was due to contaminants though, not because of this play.
    I guess a couple of years of fiddling with the original UM had some benefit after all heh.
    Just as a point of reference... my bowden tube and clip assembly at the hot end have about 1.5mm of play - and always has. It's hard to see down at the end of the bowden tube where it goes into the white coupler, because of the spring, but it seems that the tube does move at that point, but perhaps less than 1.5mm - probably because of a little tension in the tube between those two points. Certainly the bowden tube isn't coming out of the coupler as a result of the movement.
    Under the coupler, the gap between the metal part and the coupler is 2.5mm on my printer.
    I did notice that the top of the spring at the coupler/tube junction was covered in white powder - ground down bowden, I guess?
    But it's still working perfectly, so I'm not about to pull any of it out and start analyzing it :-)
    So... I think that the problem is probably to do with the seating of the bowden and the coupler somehow allowing soft filament to expand into a space where it shouldn't. Having the bowden move isn't ideal, but clearly there's some degree of movement that's acceptable before it causes a problem.
    Damn, I was about to ask you how your bowden tube behaves, and this isn't the answer I hoped for :)
    The gap under the coupler, between the metal part and the coupler is at 1.2mm on mine. So maybe there isn't enough tension to keep the bowden tube in place.
    It would be interesting to see the tips from a filament change, if you have one illuminari.
    the other issue is material unspooling, if ever you actually hear the filament untangling as it unspools, there's a chance it's requiring enough force to cause under extrusion.
    I think these two issues are the cause of 95% of my troubles, initially I was falsely diagnosing it as a blocked nozzle.
    I did the same thing - pulled up hard on the bowden. The ring held up by the red clip moves up and down a bit - I've noticed it before and was thinking of printing a thicker clip to replace the red clip. I measured it just now and with a strong pull (maybe 5 to 10 pounds force) it moves less than 1mm. About .5 to .8mm.
    Looking down at the spring area I see nothing happening there. I looked from different angles. And through those holes in the metal. Nothing is visibly moving. The bowden is probably going up and down but you can't tell because it isn't dirty or scratched enough to see movement.
    And in this image that sander posted my gap is 2.2mm:
    Print head Ultimaker 2
    Sander corrected himself later on that thread though regarding that gap.
    My Bowden tube is still coming out, any suggestions on how to keep it there? This is a really silly problem to be having, days and days of wasted time and frustration due to a poorly designed fitting.
    Sander's correction was that it had to be more than 1mm (not less). And 2mm is probably better.
    This is a common problem. There are 2 very common causes. Either the tube is defective or the "fitting".
    Take the tube out and look inside the fitting. There should be metal blades inside. They can get bent backwards so that they no longer work or can fall out or break. If the blades all look fine and are symmetrical then the problem is with the tube. If the"fitting" is defective you need a new one. I have no idea where to get new ones other than through UM: support.ultimaker.com
    bad tube: One of the times the tube was removed (either by you or by pressure) the tube got a thin layer scraped off. If you look at the tube very carefully you might see that it is thinner or different where the blades "bite" into it.
    Anyway if the tube is "bad" it's very easy to fix. Just cut off 5 to 10mm from the end and now the blades will bite into the bowden tube higher up where it isn't damaged yet. Of course you can only do this a few times before you will need a new bowden.
    Or maybe I misunderstand. Maybe nothing is wrong with the bowden nor the fitting. Maybe you just didn't assemble it "tight" enough per Robert's directions (earlier in this thread post #43). I'm not sure 3 or 4 turns is tight enough though - maybe more like 6 but I don't know as I haven't taken this apart myself.
    I've assembled it a bunch of times, each time making sure it's pushed into the teflon part as far as it will go.
    The teeth on the clip / fitting all look ok, though very small, the clip just doesn't seem to be up to the task.
    My tube is definitely scraped on the sides though, due to pulling apart so many times.
    I wonder if some teflon tape around the tube might help?
    @braddock: I don't know if this is such a good idea. If pieces of the teflon tape get inside the bowden tube, you'l get another clog/plug for sure.
    Just cut 5mm off the end of the tube so that the blades cut in to fresh virgin bowden tube.
    I just meant putting the tape around the outside of the tube where the collet clamp is, nowhere near the hotend / tube end.
    gr5 - It also has scrapes from removing the black clips that hold the cable netting and bowden tube together, but I might give that a go.
    The actual collet just looks like a generic part you should be able to find in a plumbing store, I'd like to know where UM source them from.
    I believe they are specialty. Used in air conditioner low pressure water lines only. Very very specific application and although the tube is common the different types of "fittings" are varied and only one, rare one, is the correct one.
    I looked on mcmaster carr and couldn't find it. If it's not on mcmaster carr then it's damn hard to get. Although it may have been there but just difficult to find.
    You can probably get them at a plumbing supply place that deals with plumbers that deal with commercial air conditioning. But not at a typical hardware store.
    Aren't they some variation on these:
    http://www.mcmaster.com/#push-to-connect-tube-fittings/
    Yeah - I think I found those. But those aren't the same as on the extruder or head, right?
    Those are the ones that are on the UM1... on the 2 I'm not sure - maybe one of the 'drill and install' install types? (plus the c-clip).
    I thinking some kind of mod / hack is needed. It's too common a problem not to be addressed by a better solution. A drill style mechanical collet would be a better design.
    Well mine have never slipped. But I've also never taken out the bowden on either machine because I'm afraid of damaging it.
        • 10 replies
