Hey, all...
i have the same problem, but my letters are raised. Cura merges the 2 models I made in Blender but begins printing the words at the layer that my model orientation is in.
In Blender, I took 2mm high letters and inserted them 1 mm inside a 3 mm disk. (so a 4mm high model) Exported and merged and it sliced the letters 1mm below the surface just as I had it in Blender (how do it know?). It prints a layer of letters, then a solid layer, then letters, etc. printing 1mm logo inside the disk and the remaining 1mm above the disk instead of waiting and just printing the top 1 mm on the surface of the disk. I went back to Blender and moved the logo up .5mm...still inside the disk, and Cura "knew" I had raised the logo and still printed the whole 2mm starting at whatever layer was .5mm below the top.
How does Cura know what orientation my models are in Blender and why is it printing the hidden geometry. Im using an S3 so its a 2 color print...I Import the models individually and when I merge...its in the same orientation as Blender...magic!??!! So basically Cura is printing 2 full models and starting one inside the other.
If I don't have the models in Blender in their proper places when I export each to stl, then Cura doesn't merge them right..
Ugh, long post, sorry-
Thx-
MadNess
ahoeben 1,850
Hard to tell from these images. If you save a project (File -> Save Project...) and post it somewhere (google drive, onedrive, dropbox, etc), we can have a closer look at both the model and the settings you currently use.
Edited by ahoebenLink to post
Splatman 0
The slicer might be treating the face as a solid, unbroken surface. See if drawing lines connecting the letters to each other and to the edges will solve the issue. I've had the same problem with files created in Sketchup, so it might be the same here.
